Part Number: HD3SS214
Other Parts Discussed in Thread: TDP142,
Dear all,
I designed and fabricated a PCB board named 1.4 Display Port 2x2 Switcher using Switch HD3SS214 and Re-Driver TDP142 ICs. When I tested my PCB board, I found out my monitor only detected fullHD signal from source, but the monitor can not detect 8K Signal. I configured my board as the instruction in both IC's datasheets. The AUX is routed following the HighSpeed Signal routing. The configuration of AUX Signal is as the image below:
I want to know that whether I make mistakes with the configuration above or if the configuration is correct, are mistakes in my PCB LAYOUT?
I am looking forward to hearing from you.
Thanks and Best Regards,
Buu VO
