TPS65988: Difference with TPS65988DJ
Part Number: TPS65988
Can you please advise the difference between these two?
We tried comparing the parts and found that only the markings are different.
Thank you
  • Hello Elisha,
    So from a physical point of view, these devices are identical. However, the internal ROM/RAM are designed with different end equipment's in mind. The TPS65988DJ is meant for Thunderbolt host devices, where the TPS65988 is for all other applications.
    Hope this helps answer your question.
