Part Number: TPS65982
The datasheet states that an unused GPIO pin should be pulled-down through a 1 Mega Ohm resistor.
Can a single resistor be shared by multiple unused pins? If so, what's the limit on sharing? (N * i * 1 Meg < VIL ?)
Ed
Ed
Hi Edward,
Each unused GPIO will need their own 1M pull down resistor.
Adam,
Thanks for your fast reply.
I'm still unclear as to why each unused GPIO pin needs a separate 1 meg resistor...
If all pins initialize to inputs upon power up, why can't a single resistor be shared among several inputs?
Ed
Hi Edward,
The design could work with having a common 1 meg pull down resistor, but all the reference schematics I have seen have their own 1 meg pulldown so that is what I know works. Is this a prototype board? Can try to implement a 0 ohm resistor scheme that allows for all of them to be pulled down via a single 1 meg resistor, as well as the option to where each unused GPIO has their own 1 meg resistor.
