Part Number: TCAN1042HGV
Dear,
We find some question about TCAN1042HGV , IF Vcc dely to VIO 100ms will be shunt down.
below as schematic:
If any suggestion, Please advise me.
Tom
Dear,
below as schematic:
Tom
Tom,
Just to make sure I understand, are you seeing an issue with the device starting up when the delay between VCC and VIO occurs? Or are you asking if you should expect problems because of the delay?
A 100 ms delay between VCC and VIO shouldn't cause any problems, because the transceiver not going into normal mode until the VIO passes the undervoltage threshold of ~2V (typically).
