Part Number: TLIN1029-Q1
What are these diodes used for?
What happens if these diodes are not mounted?
Akaba-san,
The master node pull-up diode is a requirement from the LIN standard. This diode is mandatory to prevent an uncontrolled power-supply of the ECU from the bus in case of a ’loss of battery’. The diode on the VSUP line right after VBAT is a reverse-battery protection diode. This is common in automotive ECUs, are connecting the battery in the incorrect, reverse orientation is common in vehicles (user error).
Please let me know if you have any other questions.
