Part Number: PCA9515B
Hi E2E,
Good day!
On section 8.1 page 8 of the datasheet, it is stated that "the input voltage of each internal buffer must be 70 mV or more below the low level output when the output is driven low internally". However, on the Table 6.5 page 5, it is indicated that Low-level input voltage below low-level output voltage is typically 120mV.
May I know what is the difference between the two?
Thank you for your usual support.
Franz
