Part Number: LMH1297
Hi,.
is it possible do LMH1297 INVERT IN0 polarity ?
thanks
Hi Nasser,.
Host was SFP Golden Finger (pinout as attachement ),
when the wiring into pcba,it`s +/- swap issue 。
(PCB layout left IC,right is Golden Finger)
please help to suggest it
LMH1297 Pin NO. |
Datasheet Name |
Application Requirement |
19 |
IN0 + |
Differential - |
18 |
IN0 - |
Differential + |
Hi Stanley,
Please note LMH1297 programming guide section 3.14. Through register settings, you can invert output polarity on any of the outputs. Please connect input IN0 to accommodate your pcb layout then you can invert output polarity as you wish.
Regards,, Nasser
