Part Number: TUSB8041
Hello!
Teacher,I want to ask some questions.I want to make a usb hub with 7 ports. If I use TUSB 8041,can I need write a program?
I hope teacher can give some help,thank you very much.
Hello!
To make a 7 port you will need to cascade two TUSB8041. Are you hoping to make a USB3 7 port hub? No programming is required for this kind of application. An EERPOM can be used to enable additional features listed in the datasheet in each hub through I2C mode.
Thank you very much.I will design the circuit. IF I have other questions, may be need teacher help.
