Part Number: TPS65983B
Hi Team,
Our customer is asking for AR (Alpine-Ridge - Apex Creek) TI TPS65983A to change TPS65983B,
Is there a difference in settings (FrimWare. & HardWare)?
thanks
Kevin
Hi Team,
thanks
Kevin
HI Kevin,
TPS65983A is compatible with firmware versions in the 4.x series. This firmware only supports PD v2.
TPS65983B may run either 4.x or 6.x series firmware. The 6.x series firmware is updated to support PD v3.
If you move from 4.x to 6.x series firmware, you should ensure you use an updated Application Customization project.
Scott
