Part Number: SN75DP139
Hello, I would like TO know how SN75DP139 adjusts EQ and the reference design of DP TO DVI, thank you!
Please refer to Figure 18 of the DP139 for the gain vs frequency curve.
Please see attached for the reference design.
David
Dear David:
Thank you for your reply, in addition, I would like to ask about SN75DP139 DATASHEET mentioned content, whether there are the lines of this part descriptions or explanation, the original content is as follows:
The resistor is added to the outputs of the driver, thereby increasing the impedance at the line source and preventing signal reflection off the driver end. The resistor value is chosen to match the source and trace impedance.
David
