Part Number: TPS65987D
Other Parts Discussed in Thread: TPS65981
Hi.
I am designing a UFP only device using TPS65987D.
VIN_3V3 is supplied by a power source (not using VBUS)
Power switches are not used, both of them are connected to GND.
I used TPS65981 Application Customization Tool to make configuration file following below steps:
New Project > TPS65987DDH > Standard > UFP only > NONE
without changing anything else.
However, after powering up the device, I found both CC lines kept alternating between High and Low which means the device is running in DRP mode.
Is there any mistakes I may made?
Or could you provide me a well-checked UFP only configuration please?
Thanks.
