Part Number: DS160PR410
Hi team,
We have 3 questions in below and need your help!
1. For the SN_SMB pin, there are 4-level inputs pins as the datasheet mentioned in below link page 12, table 3 and that says the resistor must less than 10% tolerance.
http://www.ti.com/lit/ds/symlink/ds160pr410.pdf
But we see the EVM board schematic for ENSMB with different design resistor value as below link page 17, R6/R7/R8. Why the design is not as the datasheet mentioned?
http://www.ti.com/lit/ug/snlu252/snlu252.pdf
2. For RXDET setting, what is the recommend default setting?
3. What are the difference for VOD and GAIN setting? Could you help explain more detail to us?
Thank you very much!
