Part Number: DP83825I
Hi, Team,
The INTR/PWRDN pin of Pin Functions in the data sheet is Active I. Isn't this active O?
Satoshi Yone
Hi, Team,
Satoshi Yone
Hello Satoshi,
You are correct, in Active mode when configured to INTR, this pin is an output. I will log this as an error on the datasheet that will be fixed in the next refresh. The datasheet change should reflect to say active I/O because it can still be an input if configured to PWRDN.
Vibhu
