Part Number: SN75DP159
Hello, currently there is your company's SN75DP159RGZ chip, which USES the balance function of DP to DP. However, some problems were found in the process of DP debugging. We need to check the function of DP159 code register.
In SLLA358 datasheet (turn on DP DP DEMO document) found specifically DP159 X-ray Mode Registers (SLLA359) document, please help send the DP159 X-ray Mode Registers documents, thank you!
