Part Number: DP83867E
Hello, quick question for the forum members regarding the Boot Strapping on the DP83867 PHY. On page 37 of the datasheet they have the boot strapping pins highlighted in yellow. I notice on RX_CTRL it has Mode 4 highlighted which as I read it Autoneg Disabled. Why is highlighted? Is Mode 4 set to disable Autoneg and Mode 3 to enable?
Last, on GPIO_0 if I set it for MODE4 will that cause the PHY not to work or just disregard the setting if you are using SGMII? I am using SGMII to interface with my ARM+DSP.
Thank you very much,
Joe
