Part Number: TUSB8020BEVM
Good day
I also need TUSB8020B windows EEPROM utility tool.Please send it to me.Thanks.
My e-mail adress is nico.bai@poly.com
many thanks
Good day
many thanks
hI,
I have installed the utility, but can't modify the EEPROM values. No matter what I wrote, it is always 'FF' read back.
How can I modify the values? I'm using a 'TUSB8020BPHP_REVA' dev board.
Could you reload the picture? I cannot see it on my side. Please look into folder C:\Program Files (x86)\Texas Instruments Inc\TUSB80xx EEPROM Programmer and find a user guide as well that may help.
Hi Nico,
What are you trying to program? I do not recommend using the OTP tool unless you are sure on the final configuration of your USB Hub. Have you cleared the EEPROM before trying to write? Also what is the address of your EEPROM?
Hi Malik,
I'm trying to program EEPROM to confirm some configurations. Maybe OTP is the next step.
I do have cleared the EEPROM.
I'm useing a TUSB8020BPHP develop board, looks like the address is consistent.
Hi Nico,
Is Write Protect enabled? If so it should be disabled before trying to write to the EEPROM. Are you able to read/write from EEPROM with external I2C master?
Hi Nico,
Is there any more support needed for this issue? If so please reply with any relevant details so that I can further assist you. For now I will be marking this thread as "TI Thinks Resolved". If you have resolved your issue, please post the solution to the original problem/post for others with similar issues.
Hi Malik,
Can you also send me the Windows Utility?
Email address: royhsu@ti.com
Thanks!
Roy Hsu
