Part Number: TPS65987D
Hi all:
Please help confirm the toll that the DisPlay port section and Transmit identity data object section configuration is OK?
Hi all:
Yes, your configuration settings seem to be fine and you should be able to use the DisplayPort Alternate Mode if everything else is setup correctly.
If you are interested in additional information regarding DisplayPort Alt Mode, you may also refer to its application note here: http://www.ti.com/lit/an/slva844b/slva844b.pdf
Thank you,
Hari
