Part Number: SN65HVD230
Hi sir,
We are using SN65HVD230 CAN transceiver for our application, Here whatever data transmitted to the TXD from the MCU, the same data was reflected from the RX pin of the SN65HVD230 IC, When it is connected with load or Idle.
- CAN H and CAN L waveform is perfect.
- Split termination method is used.
- Common mode of the split termination is not connected with Vref pin.
