Part Number: DP83867CR
What type of twinned RJ-45 is better to choose if we plan to use 2 pcs of DP83867CR in one board? Do you have any recomendations? Are there any specific requirments for the choosing RJ connectors?
Thanks in advance!
Thanks in advance!
Hi Aleksey,
Please refer to our User's Guide for our EVMs for our recommended RJ 45 connectors.
http://www.ti.com/lit/ug/snlu176/snlu176.pdf
Let me know if you have further questions, if not, we may close this thread.
Cecilia
Dear Cecilia,
I saw this User's Guide. we tested this demoboard. But I need some recomendations regarding vertical 2 slots RJ-45 connector, because we plan to use 2 pcs of DP83867CR on one board. Does it matter what kind of 2 slot RJ-45 connector better to use?
Thanks in advance!
Hi Aleksey,
Apologies on the delay. What is your application for using 2 slot RJ-45 connectors? Will you potentially have two boards running through the PHY or will it be a switch?
Cecilia
Dear Cecilia,
this component will be used in the inductrial computing system. It will be 2 independent boards. I hope you'll be able to advise something. Thanks in advance!
Hi Aleksy, please refer to our industrial TI design using two DP83867s and includes a two port RJ45 connector. This may be useful for your design as reference. Hope this helps.
