Part Number: SN65HVD230
Dear Sir,
We need to know the TI SN65HVD230 CAN bus transceiver's layout guideline. Our question as below.
1. The CANH and CANL for differential signals connect from IC(SN65HVD230) to connector
a. What is the maximum total trace length on PCB?
b. What is the maximum trace length mismatching for CANH and CANL?
c. Will termination's R,C be close to IC(SN65HVD230) or connector?
d. What is the maximum trace length from IC(SN65HVD230) to termination?
e. What is the maximum trace length from termination to connector?
2. The TXD and RXD for signals connect from MCU to IC(SN65HVD230)
a. What is the maximum total trace length from MCU to TI transceiver on PCB?
b. Is there a need to match the trace length between TXD and RXD? If yes, what is the maximum trace length mismatching for TXD and RXD?
Thank you
Kevin
