Part Number: TUSB8044A
Hi team,
Is there any problem to input signal from up/downstream before USB HUB IC is powered up?
Saito
Hi team,
Saito
Saito-san,
Do you mean USB signals? For the host this is not a problem, but the downstream devices can possibly backdrive voltage into the hub, so an active reset on GRSTz would be recommended to ensure a clean power on reset condition when the USB Hub IC is powered.
JMMN
Hi JMMN-san,
Yes.
Is the backdrive voltage possibly cause of the incorrect operation of hub IC? Do you just concern about the backdrive voltage test in the USB compliance test?
I just want to clarify. The signal from up/downstream doesn't damage the device when the power isn't supplied to hub IC. Is that correct?
Saito
