Part Number: TUSB9261
We have a specific need where we'd like to connect a TUSB9261 to an FPGA on the transceiver, that will play a sata role. as well as accessing the GPIO.
How can we get the datasheet of the SoC in order to implement that. Other than that, we'd like to access the firmware source code to use it as a base for the development.
I've seen in old forums that TI does provide those source code in certain case. We can see that other companies had access to the same requirement for developing USB-3 based application that does not necessarily convert USB3 to sata, but gives access to the EP (example here https://www.usb-midi.com/ )
