Part Number: SN65C1167
Other Parts Discussed in Thread: AM26LV31E, AM26LV31
Hi team,
Would like to consult with you about our SN65C1167 whether can support 60MHz spi buffer.
My customer has search out the below AP which is using SN65C1167 to implement SPI buffer.
It doesn't mention about the speed about the SPI signal but the propagation delay of 1167 should be higher than expected if using at 60MHz SPI signal.
Whether SN65C1167 is still a suitable solution for 60MHZ SPI signal? Thank for your comment.
