Part Number: TPS65988DJ
To implement "UCSI: Get Connector Reset" command manually through EC, should EC sent GAID or HRST or anything else?
Thanks!
Antony
Thanks!
Antony
Hi Scott,
May I know what does "4cc command : UCSI-Connectror_reset" exactly do in the FW? My customer's application is a host system (laptop), and it's an old prokect that they hadn't started to use UCSI 4cc command to accomplish UCSI tasks.
Currently they send GAID to achieve UCSI_Conector_Reset, Do you think GAID is too much for them? Do you think they can simply send HRST to achieve UCSI_Connector_Reset?
Thanks!
Antony
Hi Antony,
There will be trade offs for each option. If the customer can tolerate the reboot process that will be triggered by GAID and it is already working then I think it is an okay solution.
HRST has the advantage of leaving the device up and should complete faster but will cause PD traffic that other options will not.
Scott
