Part Number: TCAN1043-Q1
HI ti team,
1, Could you pls help us check how to test the nfault pin in can bus failures?
I test in normal mode,short the CANH to GND,the nfault pin also is high no changed to low
2, in Standy mode, if use can bus to wake up,the nfault pin also is high no changed. Can I wake up the MCU with Nfault pin when Can bus signals?
