Part Number: TMDS442
Hello team,
Would you please advise about TMDS442 schematics design as below?
Q1) Can we set to floating at Local I2C (LC_SCL,LC_SDA, LC_A0, and LC_A1) when we do not use Local I2C?
Q2) Can we set to floating at DDC pins(SCLx, SDAx, SCL_SINKx and SDA_SINKx) which we do not use?
Q3) Can we set to floating at TMDS source channels which we do not use?
Q4) Can we set to floating at 5V_PWRx because there are pull-up resisters?
Q5) Does Bulk Capacitor such as 1uFor 2.2uF is needed except for 0.01uF at power line ?
Q6) We use 4.64kohms between VSADJ pin and GND. Is it correct or not?
Q7) Can we connect Thermal Pad to GND?
Your advice would be so appreciated.
Akihisa Tamazaki
