Other Parts Discussed in Thread: DS25CP102, LMH0324
Hello Forum,
I searching for a solution to swicth between two Cameras with an Interface Board that transmit a HD-SDI Signal to a 75 Ohm Coaxial Cable.
Each Camera has its own Interface Board with a 75 Ohm BNC Connector. So I have to switch between this two Datastreams to one 500m Cable.
The Output Signal is HD-VLC witch allows a 1.485Gbps HD signal to be transmitted.
Which Chip is the right choice? I have found the DS25CP102 Cross Point Switch. Can I use this CHIP?
Thanks for your answers.
