Part Number: IO-EXPANDER-EVM
Other Parts Discussed in Thread: TCA6424A
Hi
I use IO Expander EVM to do IO port expansion experiment,as the User's Guide show
My first question is the User's Guide descript that “flashes the firmware to the LaunchPad using the MSP430Flasher.exe and IO_Expander.txt Files” But I failed try to do this.I wander that update the firmware without link the emulator and setup driver? could you please explain the steps to update the firmware?
Second question is when test TCA6424A, set GUI to control P02 (P02_24 on PCB) and P03 (P03_24 on PCB) the IO Expander EVM and the respective LEDs,There are no check-box besides P02 and P03 and it can not turns on or off the LED when uncheck the "P02/P03 OUT items" of EVM. Thanks a lot !
Best regards!
Riffin Li
