Part Number: TLK10232
I want to use port A ,don't use port B, when don't use port B ,what does port B pin need to do(float or short )?Who can tell me,thanks,have a pin checklist about tlk10232?thanks!
You may float port B I/O pins and assert PDTRXB_N. See pin description below.
PDTRXB_N pin: Transceiver Power Down. When this pin is held low (asserted), Channel B is placed in power down mode. When deasserted, Channel B operates normally. After deassertion, a software data path reset should be issued through the MDIO interface.
Rodrigo Natal
HSSC Applications Engineer
