Part Number: SN65C1168
What is the maximum data rate RS422 transceiver SN65C1168 support.?
Cheers,
Pradeep
Hi Pradeep,
This device is intended to support up to 10 Mbps. In some cases faster operation could be achievable. For an analog transceiver device like this, the primary limitation on data rate is the transition time of the output signal. A general rule of thumb is to make sure that the signal transition time is less than one third of the bit period.
Max
