Part Number: DP83849I
We are using DP83849I in our design. In the website there is no direct downloadable file for the device driver. How to obtain the driver?
Hi Talents,
Please review the following thread: https://e2e.ti.com/support/archive/internal/int-ethernet/f/904/p/341737/1193729?tisearch=e2e-sitesearch&keymatch=DP83849%2525252525252520driver#1193729
Thank you,
Nikhil
Hello Nikhil,
Its seems the link not accessible to me. Below is the message. It will great if you could reply to my query, we have to freeze the design. Thanks
You do not have permission to view/download this item.
Hi Talents,
I apologize for the inconvenience. The DP83849 should be compatible with the driver for the DP83848.
Thank you,
Nikhil
Hello Nikhil,
Thanks for your response. But DP83848 I believe is a single PHY. How can we handle a dual PHY with the driver of a single PHY, since we have two PHY addresses.
Talents
Hi Talents,
The communication method is the same so there should be no issues. Please note, this has not been tested, only compile checked. Customers are responsible for their own testing.
Thank you,
Nikhil
