Part Number: SN65LVCP408
I am a beginner at PCB design and am attempting to design a analog switch that allows Base T Ethernet signals to be routed from specific inputs to outputs. I noticed that A and B are assigned positive and negative values for differential traces. This may be a dumb question but can I use the opposite to avoid crossing traces? To be more specific is it possible to route the positive trace to B and the negative trace to A? I noticed in the datasheet there is no specific maximum or minimum for either input but I realize this may be a result of the pads already being assigned there respective positive and negative values. Please let me now and thank you in advance for your time.
