Part Number: LMH0324
Other Parts Discussed in Thread: LMH1219
I am designing a power supply for 8x LMH0324 and I am looking for the worst-case power consumption. We are using a 2.5V rail.
Per the data sheet, IDD is listed as 71 mA max at 2.5V (6.4 "Electrical Characteristing") HOWEVER there is a footnote (1) indicating this value is "Measured with RSV_L tied to VSS".
Elsewhere in the data sheet, it is indicated that RSV_L is tied to VGG for 2.5V operation (9 "Power Supply Recommendations").
Confusing things further, Figure 16 (8.2 "Typical Application") shows the LMH0325 with a 2.5V rail and RSV_L tied to ground (VSS), although this configuration is not discussed elsewhere that I can find.
So...is the 71 mA maximum current accurate if RSV_L is tied to 2.5V?
Is it legal to tie RSV_L to VSS when powered via 2.5V?
Is there a maximum current specification when running at 2.5V with RSV_L tied to 2.5V?
