Part Number: AM26C32-EP
Other Parts Discussed in Thread: AM26C32
Hi.
Question:
I would like to confirm that AM26C32MDREP CAN USE this 120 Ohm termination resistor.
Besides, I would appreciate an explanation of the role and rationale for such termination in the circuit.
Explanation:
I need to transmit a TTL signal from a subsystem to another subsystem 25m away.
I decided to use AM26C31MDREP transmitter and AM26C32MDREP receiver in a 25m shielded twisted pair (in a cable assembly) transmission (TTL-RS422-TTL).
In the past I used the obsolete AM26LS31ACN/AM26LS32ACN, which would frequently get faulty and need receiver replacement.
This issue stopped when the receiver was terminated with a 120 Ohm resistor, as sugested in the old data sheet.
Well, the present data sheet for AM26C32MDREP (AM26C32-EP) in Texas Instruments website is dated 2007:
This data sheet has no mention of a termination resistor.
Nonetheless, the AM26C32 family data sheet in Texas Instruments website is dated 2018 and has somewhat more detailed electrical information.
In the AM26C32 data sheet Section 9.2 Typical Application, page 10, the termination resistor is mentioned (see Figure 4 Differential Terminated Configuration) and recommended values are 80 to 120 Ohm, just like the old AM26LS32ACN.
I am inclined to use the resistor termination since the old system would frequently get faulty receiver without it. My design colleague does not want the termination since he believes it will increase current, power consumption and decrease efficiency.
Here I add the directions to the data sheets in TI website.
AM26C32-EP Enhanced Product Quadruple Differential Line Receiver Data sheet
www.ti.com/.../am26c32-ep.pdf
www.ti.com/.../slls870.pdf
AM26C32 Quadruple Differential Line Receiver datasheet (Rev. L)
www.ti.com/.../am26c32m.pdf
Figure 4. Differential Terminated Configuration
Thank you very much for your support.
