Part Number: TPD7S019
Hi team,
Could you please review the attached TPD7S019-15DBQR schematics for our VGA buffer circuits.
I added 60 ohm series res. to match 75 ohm as the int. impedance is 75 ohm, please advise if this O.K?
Thanks in advance
Shai
Hi team,
Thanks in advance
Shai
Hi ,
We will get the feedback to you soon,thanks!
Hi Berman,
If the impedance board trace is 75Ohm, it suggest you put 75Ohm for this resistor to match.
Michael,
The device has int. 15 ohm – so I add 60 ohm resistor - this is OK?
secondly, please.advise if other connections are O.K.?
Thanks in advance
Shai
Hi Shai,
The impedance in the Video line isn't 15Ohm, But you put 60Ohm here is no problem. The termination resistors for Video is 50-75Ohm.
The pull up resistor for DD should be 1.5K-2K. You put 2.21K is a litter big.
