Hi Team,
What changes are needed if we want to move to the TPS65982ABZBHR from TPS65982ABZQZR?
Thanks!
Roy
Hi Roy,
From you or the customers perspective there is no difference between these devices.
Hi Adam,
Allow me to ask in more precise terms...in terms of hardware, is there any schematic and layout change needed? For firmware, can we re-use the firmware created for the TPS65982ABZQZR?
Thanks.
Roy
From the perspective of the customer, there is no difference between these two devices. Hardware is the same. You can use the same firmware image. The customer does not need to worry about differences between these two devices because it will not effect their system.
