Part Number: SN65LBC180
Hi team,
My customer doesn't need enable function.
So, the customer should tied /RE pin to GND. Is my understanding correct?
Yoshi
Hi team,
Yoshi
Yoshi-san,
Yes, you are correct. /RE can be tied to GND. This will make the receiver always enabled, meaning the state of the A/B lines will be reflected on the R output pin. Please let us know if you have further questions.
Max
HI Max,
Thanks for your quick reply.
Also, the customer should tied DE to VDD. Is it also correct?
Yoshi
Yoshi-san,
Tying DE to the VCC rail is OK for the device. Under this configuration, though, you should make sure that no other nodes will need to use the Y/Z lines to transmit data. For example, this would be a valid configuration for a point-to-point (two-node) network or for a "master" node in a multi-point full duplex network. It would not work for a "slave" node in a multi-point full-duplex network, though. (Please see Figure 20 in the datasheet for an example illustration of such a network.)
Max
