Part Number: TFP410
Is it feasible of this application solution? The similar post describes that it is NOT directly from FPD-Link to HDMI as following:
If not, could you please help to explain in detail? Thank you very much。
I
Part Number: TFP410
I
Hi Kailyn,
That application should be fine as long as the HDMI stream does not contain audio.
The post you are referencing is also correct, as the TFP410 is a bridge that can be used to convert to HDMI (without audio).
I.K.
Hello Anyiam,
According your answers, I still have some problem.And I gratitude your answers very much.
Whether is TFP410 include the bridge, please ?and what is the bridge ? who will finish function of the bridge, if TFP410 does not include the bridge ?
The TFP410 is an RGB888 to DVI/HDMI bridge, just as the block diagram depicts. Bridge just means it translates one interface to another interface.
I.K.
Hi Anyiam,
So is the scheme reasonable for TFP410 ?Do you mean TFP410 is bridge that you point out ?
