Part Number: DS90UB936-Q1
Other Parts Discussed in Thread: DS90UB913A-Q1, DS90UB933-Q1, DS90UB962-Q1, DS90UB964-Q1, DS90UB960-Q1,
Could you pls recommend 8/10bit DVP signal input, MIPI DPHY output solution?
thanks.
thanks.
Hello Lin,
For DVP input we have either DS90UB913A-Q1 or DS90UB933-Q1
For MIPI output we have several different solutions including hubs with different numbers of inputs and speeds. For a single or dual camera application DS90UB936-Q1 would be a good fit. If you have 3-4 camera inputs then you could use DS90UB962-Q1 or DS90UB964-Q1 or DS90UB960-Q1.
Casey
Hi Casey,
Thanks for your quick reply, any reference design or Application note could share?
Hello Lin,
I would recommend reading through the datasheets of these devices for all configuration and design recommendations. Also you can use the EVMs for these devices as a reference for the HW connections.
Casey
