Part Number: DP83822I
From the document "DP83822 IEEE 802.3u Compliance and Debug" I can see that for the Analog Loopback test of the DP83822I I need two termination resistors at the RJ45 connector.
Is it true that this test also tests the magnetics and the plug connections? Can I be shure that if this test is running ok that everything with the magnetics and connector is ok?
Thanks and best regards,
Patrick
