Part Number: TS3USB221EVM
Other Parts Discussed in Thread: TS3USB221
Please could you help.
I have designed and built a USB 2.0 4 port multiplexer using the TS3USB221.
Having followed all the guidelines for 90 ohm differential strip line design we find that the USB ports are unable to operate at 480Mb.
The design effectively has 2 TS3USB221 in series with each other.
I suspect my PCB layout so we are about to test the theory by cascading two TS3USB221 EVM modules.
One of the issues that was noted with the EVM is that the USB signal layer also has a ground plane around the differential trace.
All the design guides indicate this is incorrect (. Also, maintain a minimum keep-out area of 30 mils to any other signal throughout the length of the trace.)
Is this the issue? (My PCB does not have ground plane on USB signal layer)
