Part Number: TS3DV520E
hi
The TS3DV520E can be used as LVDS switch?
Hi Ben,
Yes, this device supports LVDS.
I.K.
The bandwidth is enough, yes. It looks like your panel is dual port LVDS though. Do you mind sharing how you plan to use the TS3DV520E? Do you want to switch between ports on one panel? Or did you want to use 2x TS3DV520E per panel and switch between panels?
I.K.
