Part Number: TRS3243E
Other Parts Discussed in Thread: TRS3243
Hi Sirs,
With 3.3V power supply, my customer got signal distortion problem with the TRS3243ECDBR device as the waveforms below:
Input Signal (RX before TRS3243)
Input Signal (TX before TRS3243)
Output Signal (RX after TRS3243)
Output Signal (TX after TRS3243)
We confirmed that there is no redundant capacitors on the signal path. Would you please provide tips to identify the problem? Should we consider another portfolio (for example MAX3243IDWR) in this case? We can discuss the issue off line as needed.
Thank you and Best regards,
Wayne Chen
02/05/2020
