Part Number: TUSB4041I-Q1
Other Parts Discussed in Thread: TUSB8020B
Hello, could you please help me with some misunderstanding?
This is the information from the datasheet: "The TUSB4041I-Q1 device provides pin-strap configuration for some features including battery charging support, and also provides customization though OTP ROM, I2C EEPROM". So the question is, can I configure pin strap to use EEPROM, but if it is empty, is it normal to TUSB4041 load default config from straps?
Or should I disable I2C EEPROM (pull-down SDA and SDA) in this case?
Should it work normally with non programmed EEPROM?
Thank you!
