Part Number: TCA9554A
Other Parts Discussed in Thread: PCF8574
HI expert,
Can TCA9554A update output ports in case of continues data writing of I2C?
- Start bit
- Slave address
- Register address
- Write Data (Output setting 1)
- Write Data (Output setting N)
- Stop bit
From Figure 23. the timing of data output from port is after writing data. So I believe, it can update each write data timings. Is it correct?
Also, Do you have any idea for I/O expander that is controllable as below? (use case is OUTPUT only)
- Start bit
- Slave address
- Write Data
- Stop bit
Muk
