Part Number: TPS65982
Hi Team,
After giving power using power adapter, non of the LED is getting on .
I am not able to flash the fw as the aardvark is not getting detected. Is there a process to flash the FW without giving power.
Abin Alias
Hi Team,
Abin Alias
Hello Abin,
No, power must be present on the board for programming. Recommend checking the adapter to see if it is supplying the necessary 20V, and then check the input for each relevant IC on the EVM to see if they are receiving their necessary voltage.
