Part Number: DP83822EVM
The customer plans to test FPGA board and DP83822EVM for evaluation. RMII interface through put is 50MHz clock. The customer has concern about the connection between FPGA board and DP83822EVM.
[Questions]
1) Have TI worked DP83822EVM in RMII mode by using DP83222EVM J13 and J14 header?
2) If yes, could you share us what kind of cable and length used?
3) FPGA board header pin assign is not pair signal and gnd. This may be disturb waveform. If there is an advise for these connection , please let us know.
Toshihiro Watanabe
