Part Number: DP83867IR
Hi
If DP83867 and RJ-45 connector is placed the board separately, which board is magnetics placed in ?
Thank you and best regards,
Michiaki
Hi
Michiaki
Hi Michiaki,
As this is not a usual this has not been tested, but you may want to place the magnetics closer to the RJ-45. This will provide protection closer to the RJ-45.
Thank you,
Nikhil
Hi Nikhil,
I understand you don’t have experience but which is your recommendation ?
And also please give your advice what customer should be consider for each designs.
Michiaki
Hi Michiaki,
As mentioned, the recommendation is to place the magnetics close to the RJ-45. You may refer to this app note for layout requirements. http://www.ti.com/lit/an/snla079d/snla079d.pdf.
Thank you,
Nikhil
