Part Number: DP83822I
I'd like to confirm the timing of the RESET pulse width. In the D/S page 6 pin configuration, it mentioned the minimum duration for RESET is 1uS at least. But in the page 11 (7.7 Timing requirement, Reset Timing), the minimum value is defined as 10uS. so i'm confused about these. could you clarify it. thanks.
BTW, is there over temperature protection inside the device? if so, what's the trigger thermal temp?
