TPS65983B: TPS65983B questions for customer
Part Number: TPS65983B
Other Parts Discussed in Thread: TPS65987D
I am an FAE in the Israeli team and my customer has the following questions:
  1. Can you send me TPS65983B Configuration Tool ?
  2. External SPI is always required?
  3. Do you have some demo configuration firmware file?
Thank you!
  • Hi Victor,
    The customer should apply to the TPS6983B secure software folder to access the Configuration Tool
    The TPS65983B is a device that always requires an external SPI flash. Consider TPS65987D as an alternative that does not.
    A TPS65983B designer is constrained to use Intel TBT Reference designs. These references will match the Projects in the Configuration Tool.
    Scott
